Retvizan
Apr 29, 2023Aspirant
CAX 30 freezes main network.
Hi all. I have a CAX 30 with an EAX 18 extender. Let's call my home network "Network". Smart connect enabled. In the Wi-Fi finder it presents as "Network" and "Network-5G". I think our devices t...
Apr 29, 2023Guru - Experienced User
Does this happen with the EAX turned OFF?
What is the distance between the CAX and EAX in feet?
Does this happen with Smart Connect enabled?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
- RetvizanApr 30, 2023Aspirant
Hello FURRYe38, thanks for helping.
I always have the EAX18 on, so no, never. However, the network lost internet connection even before I got the EAX18, I would just switch the mobile device into the LTE mode for a while, and wouldn't pay too much attention. Now I'm thinking of cancelling the mobile service to the iPads, so I need my WiFi to behave.
The distance between the two is about 40 feet and 3 walls (not load-bearing), never had an issue with signal.
Smart Connect is always enabled.
Hardware Version V1.01 Firmware Version V2.1.3.10 Cable Firmware Version V1.04.05 Connection StatusIP Address Subnet Mask 255.255.224.0 Default Gateway DHCP Server DNS Server Lease Obtained 1 days, 0 hours, 0 minutes, 0 seconds Lease Expires 0 days, 20 hours, 5 minutes, 23 seconds Event LogClear Log RefreshTime Priority Description 2023-04-28 09:12:05 Notice (6) DHCP Renew - lease parameters Time Protocol Servers modified;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-28 09:12:05 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-24 21:12:51 Notice (6) DHCP Renew - lease parameters Time Protocol Servers modified;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-24 21:12:51 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-21 09:13:38 Notice (6) DHCP Renew - lease parameters Time Protocol Servers modified;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-21 09:13:38 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-17 21:14:25 Notice (6) DHCP Renew - lease parameters Time Protocol Servers modified;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-17 21:14:25 Error (4) DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-14 09:14:27 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-14 09:14:26 Notice (6) TLV-11 - unrecognized OID;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-14 09:14:26 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-14 09:14:26 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; 2023-04-14 09:14:26 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=6c:cd:d6:7e:1f:9c;CMTS-MAC=00:01:5c:67:7c:73;CM-QOS=1.1;CM-VER=3.1; The channels are set to Auto. 2.4 is set to Ch.10, 5 is set to Ch.149 + 153(P) + 157 + 161
I will try to play around with channels today, like you suggested.
Besides my printer, there are two WiFi networks also showing -- a general Spectrum Mobile and one neighbor's of medium strength.
Let me know what you think, and I will also keep you updated.
- FURRYe38May 01, 2023Guru - Experienced User
Any Criticals, Errors or Warnings seen in the Event Logs page needs to be reviewed and resolved by the ISP.
Can you post the cable connections page please: https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
