Retvizan
Apr 29, 2023Aspirant
CAX 30 freezes main network.
Hi all. I have a CAX 30 with an EAX 18 extender. Let's call my home network "Network". Smart connect enabled. In the Wi-Fi finder it presents as "Network" and "Network-5G". I think our devices t...
Retvizan
Apr 30, 2023Aspirant
Hello FURRYe38, thanks for helping.
I always have the EAX18 on, so no, never. However, the network lost internet connection even before I got the EAX18, I would just switch the mobile device into the LTE mode for a while, and wouldn't pay too much attention. Now I'm thinking of cancelling the mobile service to the iPads, so I need my WiFi to behave.
The distance between the two is about 40 feet and 3 walls (not load-bearing), never had an issue with signal.
Smart Connect is always enabled.
| Hardware Version | V1.01 | |
| Firmware Version | V2.1.3.10 | |
| Cable Firmware Version | V1.04.05
Connection Status
| IP Address | |
| Subnet Mask | 255.255.224.0 |
| Default Gateway | |
| DHCP Server | |
| DNS Server | |
| Lease Obtained | 1 days, 0 hours, 0 minutes, 0 seconds |
| Lease Expires | 0 days, 20 hours, 5 minutes, 23 seconds |
Event Log
Clear Log Refresh
The channels are set to Auto. 2.4 is set to Ch.10, 5 is set to Ch.149 + 153(P) + 157 + 161
I will try to play around with channels today, like you suggested.
Besides my printer, there are two WiFi networks also showing -- a general Spectrum Mobile and one neighbor's of medium strength.
Let me know what you think, and I will also keep you updated.
May 01, 2023Guru - Experienced User
Any Criticals, Errors or Warnings seen in the Event Logs page needs to be reviewed and resolved by the ISP.
Can you post the cable connections page please: https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
