daydemon
Dec 31, 2020Star
CAX 80 / WIFI calling issues
Just recently upgraded from the Netgear C6220 to the CAX80. I noticed that the WIFI calling feature on my Samsung Note 10 Plus is no longer working. I cannot send or receive calls/texts over WIFI...
- Jul 18, 2021Solved:
After 7 months of painful troubleshooting we have finally found the fix to wifi calling.
It seems the culprit was "ipsec alg". The service is not found on the official firmware and therefore cannot be disabled.
For everyone with the issue:
You must contact netgear support and explain the wifi calling issues and that you'd like to try the beta firmware with the ipsec alg feature. Currently they do not have plans to release it publicly. Not sure why.
daydemon
Jul 18, 2021Star
Solved:
