davidbod
Jan 28, 2022Aspirant
CAX 80 & Xfinity Issues
I have an older Netgear C7000-100NAS cable modem that I am getting 760 Mbps out of connected to Xfinity Gig internet that I just upgraded to. I wanted to upgrade the cable modem to get more of the sp...
davidbod
I am wiling to be the gunea pig and try and solve what is going on. I had done this with the first box I received, but it was still going through the TP-Link 16 port switch. So I have a very new Windows laptop that I can try this with to completely isolate my Lan from the situation. I'll do some tests with my C7000 to get a baseline, then setup the CAX80 as you suggest, both modem routers with just cable and 1 ethernet to the laptop connected. If there are other firmware version to try I'm willing to do that to and report findings.
I'll be out for a couple hours, then I can start with the above tests.
Jan 28, 2022Guru - Experienced User
What is the model of the TP Link Switch? This a managed switch or un-managed?
I also have switches behing my CAX80 however have never encountered problems with the CAX and my switches...my switches are all unmanaged. HP and Netgear.
