davidbod
Jan 28, 2022Aspirant
CAX 80 & Xfinity Issues
I have an older Netgear C7000-100NAS cable modem that I am getting 760 Mbps out of connected to Xfinity Gig internet that I just upgraded to. I wanted to upgrade the cable modem to get more of the sp...
davidbod
So this has been my setup for the last 6 years:
C7000-100NAS Cable Modem / Router / WiFi but WiFi radio turned off
Wired Ethernet Connections:
1 - R7000 WiFi only (no router) installed on 3rd floor upstairs
2 - EX8000 2nd Wifi name installed downstairs on 1st floor
3 - TP-Link (TL-SG2008) managed switch 1st floor at TV
4 - TP-Link (TL-SG2216) managed switch 2nd floor at TV
TP-Link (TL-SG2008)
1 - To Router
2 - TV
3 - Apple TV
4 - Sonos Sound-Bar
TP-Link (TL-SG2216)
1- To Router
2- TV
3- Xbox
4- Sonos Connect
5- Sonos Amp
6- Sonos Amp
7- Synology NAS
8- iMac
9- iMac
10- Printer
This is what I tested this afternoon:
The laptop is so new it doesn’t have an ethernet port so tests using one of the iMacs downstairs
In the next 2 tests the iMac is the only thing connected to the routers
C7000 —Wired—> iMac
783.4, 759.8, 771.7 Mbps
CAX80 Factory Reset 192.168.1.1 Gateway address
CAX80 —Wired—> iMac
917.4, 920.2, 926.0 Mbps
In the Wi-Fi connection tests below when I am using the CAX80 Wi-Fi because it has a new to my network name and password, only the devices being tested are connected and the EX8000 is unplugged. When I am using the EX8000, the radio on the C7000 or CAX80 is turned off, but since this is my regular network, many other devices are connected, but not really providing traffic. Neither router has any other ethernet connections during the tests, only the EX8000 if being used.
My standard setup
C7000-100NAS —Wired—> EX8000 —Wi-Fi—> iMac about 2ft distance
The Wi-Fi radio on the C7000 is turned off and the EX8000 uses smart connect
585.3, 584.3, 573.5 Mbps
Change Modem Router
CAX80 —Wi-Fi—> iMac about 2ft distance
29.1, 84.9, 75.5 Mbps
Let’s change to smart connect as that is really bad
Enable smart connect on CAX80
iMac 3 ft
799.9, 827.8, 721.1 Mbps
Same as above
iPhone 13 Pro Max about 15 ft distance
430.9, 438.6, 398.3 Mbps
It all looks good to this point
Turn off Wi-Fi Radio on CAX80
Connect EX8000 - the only thing connected
iMac about 15 ft distance
605.3, 680.9, 693.7
578.3, 577.4, 573.6
So maybe the EX8000 has better Wi-Fi
Reboot CAX80 with Wi-Fi off EX8000 connected
All came back ok
Unplug EX8000
CAX80 turn Wi-Fi radio back on and reboot with only cable connection
iPhone connected ok
iMac didn’t connect even with manual DHCP renew attempts
Reboot iMac now have an address and connection
Now make Ethernet connections
Connect downstairs TP-Link (TL-SG2008) 8 port switch
Seems ok
Reboot CAX80
iMac took several minutes to re-establish connection
Otherwise seems ok
Connect TP-Link (TL-SG2216) 16-port switch
iPhone and iMac Wi-Fi connected still ok
This killed the connection to the 8-port switch
Spotify running on Apple TV to Sonos no connection
And 2nd iMac upstairs on 16-port will not connect to the internet even after rebooting the iMac
Reboot CAX80
Downstairs iMac didn’t reconnect even with manual refresh DHCP
Reboot iMac no luck
Reboot iMac finally back after some initial flaky connections
Spotify Sonos not connected through Apple TV
Upstairs iMac has an IP address and can be refreshed, but never connects to the internet
Connect old C7000 to cable, connect 16-port switch, 8-port switch, EX8000, and direct connect iMac so all 4 Ethernet ports occupied, turn it on.
Downstairs iMac direct wired is getting
772.0, 780.3, 766.4
Downstairs iMac through Wi-Fi to EX8000
551.0, 562.6, 579.3
Apple TV Spotify Sonos is working
iPhone 13 Pro Max
484.7, 502.0, 506.0
Upstairs iMac through 16-port switch
768.6, 752.6, 763.5
Both iMacs back upstairs direct connected to 16-port switch and simultaneous tests
iMac 1: 496.8, 374.2, 486.3
iMac 2: 327.1, 421.2, 272.5
At this point I think the CAX80 has hardware issues. It seems to be ok until you load it up, and then it craters. It's possible it doesn't like my switches, but these have been working fine for 6 years and are still working fine connected to the C7000.
- schmidt545Mar 22, 2022AspirantI am wondering if I can tie my cax 80 to the ethernet port on the tv cable box?
- michaelkenwardMar 23, 2022Guru - Experienced User
schmidt545 wrote:
I am wondering if I can tie my cax 80 to the ethernet port on the tv cable box?What do you mean? Does it have anything to do with the subject of this conversation, "CAX 80 & Xfinity Issues"?
You want to connect your TV to the internet by plugging it into the router? That should work.
