Amarks2
Mar 07, 2022Tutor
CAX 80 ethernet much slower than wifi
Basic issue--much slower ethernet than wifi speeds. After considerable trouble shooting it is clear the issue is with the CAX 80 ethernet ports, hopefully just a settings issue. Checking all ethe...
- Mar 07, 2022
Checked the PC ethernet controller early on, it reported 1 gps for ethernet connection. However, what I had not done is check the Killer network card app. Your suggestion inspired me to go back and look more carefully at all settings affecting the adapter including the app. It appears that it was throttling the intenet speed with an auto setting based on what it apparently had sensed as provider speed 90 MBS. Overriding the setting gets me to 850 MBS, not quite what I am paying for, but close enough
Mar 07, 2022Guru - Experienced User
Be sure to check the ethernet adapter on the PC as well. Make sure it's reporting 1000Mbps while connected to the modem.
Be sure it's drivers are up to date.
Try a different Pc if you have one to compare.
Is Armor enabled?
Checking all ethernet ports to multiple devices using cat 7 cables consistently yields roughly 80-90 mbs speeds on 1gig+ Xfinity connection. Meanwhile the router wifi speed is 600 mbs when measured close to the cable modem. Checking with Xfinity they (not surprisingly given the wifi speeds) found no issue on their end.
I have done the standard troubleshooting checking speeds swapping all ports, multiple ethernet connected devices and switching out various cat 7 cables to eliminate device, cable or single ethernet port specific issues. Modem has been reset and rebooted multiple times
In the "advanced-show statistics" of the Modem option all connected LAN ports show 1 gig speeds except for the LAN5 with its 2.5 gig speed. “Aggregate ports” on or off has no effect nor have multiple reboots and internet provider resets had any impact.
Any suggestions would be much appreciated.
Operating environment is Windows 10 OS, CAX 80 Firmware Version V2.1.3.5.
Amarks2
Mar 07, 2022Tutor
