Riledup1
May 20, 2022Follower
CAX 80 no WIFI
just had a brief power outage. have lan internet but no wifi. rebooted 2xs, all lights are white. router login doesn't work either. Thanks in advance.
michaelkenward
May 21, 2022Guru - Experienced User
What else is on the network? It is important to start things in the expected order so that each device takes it cues from the components up stream.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
If that doesn't work, tell us what the modem/gateway is at the head of the queue.
