peterforbes
Feb 28, 2023Follower
CAX 80 Passthrough WAN ping
Hi, I just purchased my #CAX80 cable modem/router. So far so good. My wife, daughter and I all work from home for three separate companies, each with three different VPN access solutions. M...
Feb 28, 2023Guru - Experienced User
Check to see if Respond to WAN ping is checked under Advanced Tab/WAN Setup.
Might try putting the daughters PC in the in the CAX DMZ temporarily to see if it can connect here. Remove from the DMZ after testing.
