dadabunchie
Mar 11, 2021Aspirant
CAX 80 Reboot SSID Changed
CAX80 rebooted sometime last night and suddenly SSID changed to a different name. Spectrum probably dropped (still having slowness issues) and caused the reboot. Anyone experience this before? ...
Mar 11, 2021Guru - Experienced User
I've had it happen where it defaulted back to the stock ssid/password.
- dadabunchieMar 11, 2021Aspirant
It didn't default back to the original SSID which I never changed OOB but to a completely different SSID.
It is on FW 2.1.1.4 (which is the latest i think)
I think its just a glitch but kind of disconcerting. It's been pretty stable until this event.
- CompuSmithAug 07, 2021AspirantI had same issue. New FW has been released to 2.1.2.6. Solved my problem but, new problem is the backup doesn't either capture or restore everything. Different results with every backup. Cannot get backup/restore to restore Device names though.
- FURRYe38Aug 07, 2021Guru - Experienced User
Factory reset the CAX and then setup from scratch. After you have set up the CAX, save off a new backup configuration to file.
