trevorh123
Feb 01, 2023Tutor
CAX 80 Slow wifi speeds
Hello, I've seen numerous threads about the CAX 80 having slow speeds over wifi using Xfinity and it seems I'm having the same issues. I've been with Xfinity for almost a year now, and have ...
trevorh123
Feb 01, 2023Tutor
Is this it?:
Qualcomm QCA61x4A 802.11ac Wireless Adapter
I also just did another update through Dell and am getting the same results. đ
Feb 01, 2023Guru - Experienced User
That wireless card isn't going to hit gigabit speeds. the 400-500mbps that you're getting is about all it can get.
Do you have a different wireless device to test with that supports wireless AX?
That's the only thing that might get close to gigabit.
- trevorh123Feb 01, 2023Tutor
I have an iPhone 13, and I'm getting just anywhere between 600-800mbps.
At this point, I'm assuming it's the card installed in my laptop that is limiting my wifi speed?
- plemansFeb 01, 2023Guru - Experienced User
Your iphones speeds are about what you can expect too as its doesn't support 160hz wide channels. So its best link speed is 1200mbps. And actual throughput tends to be around 55-65% of link speed. So hitting that 600-800mbps is about what you'd expect.
Your laptop card is your limiting factor on it. You might check as some laptops its fairly easy to upgrade the wireless card in them. I've done it to a couple and its not really that expensive if you diy it.
Got it! I'll look into upgrading the wireless card and see where that takes me.
Thank you!
