dasumner's avatar
dasumner
CAX 80 Upload Issues
I replaced the Xfinity-supplied modem/router with a CAX80.  I've noticed that I'm not able to upload files of any size via a browser.  The only exception is when I'm logged into my company VPN.  This is consistent across multiple devices and when I'm using WiFi and wired connection.  I'm not sure what I should check in order to troubleshoot.
Hardware version: 1.0.1
Firmware version: 2.1.5.2
Cable Firmware version: 1.02.08
  • FURRYe38's avatar
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    What channel configurations are currently set on the router?
    Armor, Smart Parental Controls or Traffic Meter.
    • dasumner's avatar
      dasumner
      Armor, Parental Controls and Meter are all turned off.
      Cable Diagnostic
      Status: Good
      Action: Your setup looks fine. If you are still experience an internet issue, the Netgear Cable Knowledge Base can provide additional troubleshooting info.
      Internet Access: Good
      Downstream Status: Good
      Downstream Power Level: Good
      Downstream SNR: Good
      Upstream Status: Good
      Upstream Power Level: Good
      Current time: Mon Apr 01 09:17:11 2024
      Startup Procedure
      Acquire Downstream Channel: 549 MHz Locked
      Connectivity State: OK Operational
      Boot State: OK Operational
      Security: Enabled BPI+
      Downstream Bonded Channels
      Channel LockedStatus Modulation ChannelID Frequency Power SNR Correctables Uncorrectables
      1 Locked 256 QAM 20 549000000 Hz 4.6 dBmV 43.5 dB 8448 8107
      2 Locked 256 QAM 13 507000000 Hz 4.5 dBmV 43.7 dB 10244 10367
      3 Locked 256 QAM 14 513000000 Hz 4.5 dBmV 44.6 dB 9096 8351
      4 Locked 256 QAM 15 519000000 Hz 4.8 dBmV 41.9 dB 11520 11138
      5 Locked 256 QAM 16 525000000 Hz 5 dBmV 43.5 dB 7748 7724
      6 Locked 256 QAM 17 531000000 Hz 4.6 dBmV 44.1 dB 9662 10937
      7 Locked 256 QAM 18 537000000 Hz 4.5 dBmV 44 dB 8512 8327
      8 Locked 256 QAM 19 543000000 Hz 4.4 dBmV 43.6 dB 10086 11941
      9 Locked 256 QAM 21 555000000 Hz 4.9 dBmV 44.5 dB 11411 14473
      10 Locked 256 QAM 22 561000000 Hz 5.1 dBmV 44.9 dB 8477 8203
      11 Locked 256 QAM 23 567000000 Hz 4.8 dBmV 44 dB 11681 12934
      12 Locked 256 QAM 24 573000000 Hz 4.8 dBmV 41.7 dB 9138 8817
      13 Locked 256 QAM 25 579000000 Hz 4.9 dBmV 43.8 dB 9889 10047
      14 Locked 256 QAM 26 585000000 Hz 4.9 dBmV 44.6 dB 8242 8036
      15 Locked 256 QAM 27 591000000 Hz 4.9 dBmV 44.1 dB 12991 10335
      16 Locked 256 QAM 28 597000000 Hz 5 dBmV 43.1 dB 7058 6721
      17 Locked 256 QAM 29 603000000 Hz 5.1 dBmV 43.4 dB 9445 8193
      18 Locked 256 QAM 30 609000000 Hz 4.7 dBmV 44.6 dB 6991 6841
      19 Locked 256 QAM 31 615000000 Hz 4.6 dBmV 44.5 dB 6719 6518
      20 Locked 256 QAM 32 621000000 Hz 4.6 dBmV 42.3 dB 6925 6876
      21 Locked 256 QAM 33 627000000 Hz 4.7 dBmV 37.6 dB 6963 6469
      22 Locked 256 QAM 34 633000000 Hz 4.8 dBmV 40.2 dB 6133 5663
      23 Locked 256 QAM 35 639000000 Hz 4.4 dBmV 42.2 dB 5711 6315
      24 Locked 256 QAM 36 645000000 Hz 4.3 dBmV 42 dB 6241 6127
      25 Locked 256 QAM 37 651000000 Hz 4.2 dBmV 44.2 dB 5423 5745
      26 Locked 256 QAM 38 657000000 Hz 4.1 dBmV 44.2 dB 6082 6883
      27 Locked 256 QAM 39 663000000 Hz 4 dBmV 44.1 dB 6707 6880
      28 Locked 256 QAM 40 669000000 Hz 4.3 dBmV 44.2 dB 5636 5477
      29 Locked 256 QAM 41 675000000 Hz 4.2 dBmV 43.2 dB 6626 7248
      30 Locked 256 QAM 42 681000000 Hz 3.9 dBmV 44 dB 6216 6235
      31 Locked 256 QAM 43 687000000 Hz 3.8 dBmV 44 dB 5400 5169
      32 Locked 256 QAM 44 693000000 Hz 3.6 dBmV 43.9 dB 6183 6588
      Upstream Bonded Channels
      Channel LockedStatus ChannelType ChannelID SymbolRate Frequency Power
      1 Locked ATDMA 19 5120 Ksym/sec 29200000 Hz 39.0 dBmV
      2 Locked ATDMA 18 5120 Ksym/sec 22800000 Hz 39.8 dBmV
      3 Locked ATDMA 17 5120 Ksym/sec 16400000 Hz 40.8 dBmV
      4 Locked ATDMA 20 5120 Ksym/sec 35600000 Hz 38.5 dBmV
      5 Not Locked Unknown 0 0 0 0.0
      6 Not Locked Unknown 0 0 0 0.0
      7 Not Locked Unknown 0 0 0 0.0
      8 Not Locked Unknown 0 0 0 0.0
      Downstream OFDM Channels
      Channel LockedStatus ProfileID ChannelID Frequency Power SNR/MER ActiveSubcarrier Unerror Correctable Uncorrectable
      1 Locked 0 ,1 ,2 ,3 193 957000000 Hz 2.18 dBmV 41.5 dB 148 ~ 3947 1925226449 1111247400 3434
      2 Not Locked 0 0 0 Hz 0 dBmV 0 dB 0 ~ 4095 0 0 0
      Upstream OFDMA Channels
      1 Not Locked 0 0 0 Hz 0 dBmV
      Event Log
      Time Priority Description
      Mon Apr 1 09:13:37 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 09:12:15 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 09:07:50 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 09:05:14 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 09:04:16 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 09:02:54 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:52:45 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:52:03 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:50:19 2024 Critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:42:59 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:37:14 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:36:28 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:33:03 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:31:18 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:29:59 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:22:27 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:20:00 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:15:35 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:12:01 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 08:01:35 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 07:55:53 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 07:48:38 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 07:45:05 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 07:43:05 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 07:39:43 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 07:20:52 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 07:19:36 2024 Critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 07:16:36 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 06:39:09 2024 Critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 06:23:05 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 06:17:39 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 06:13:38 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 06:07:08 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 05:21:40 2024 Critical Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 05:21:10 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 05:19:11 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 05:17:42 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 05:13:09 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 05:08:18 2024 Notice CM-STATUS message sent. Event Type Code: 16; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Mon Apr 1 05:07:58 2024 Notice CM-STATUS message sent. Event Type Code: 24; Chan ID: 193; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=80:cc:00:00:00:bb;CMTS-MAC=00:00:ff:00:00:00;CM-QOS=1.1;CM-VER=3.1;
