Retired_Member
Aug 21, 2022CAX 80 Using a router based VPN
Will installing a VPN on my CAX80 router modem cause problems with streaming services? Will streaming over ethernet circumvent any issues?
- Aug 21, 2022
The feature that is part of your CAX80 is an Open VPN server. It allows you to connect from the outside internet back to your LAN.
What you are talking about for streaming from the outside in, is an Open VPN client. There is no option for that configuration on the CAX80. In particular when you have a combination cable modem/router gateway where the firmware is controlled by the internet service provider.
There are some routers with third party firmware that will allow running an Open VPN client so you can connect to an outside VPN service that has servers in foreign countries. However, none of them are a combination cable modem/router gateway.
You can check out either the Netgear R7800 or R9000 routers running Voxel firmware with the Kamoj addon over on Small Net Builders. https://www.snbforums.com/forums/netgear-ac-wireless.53/ You would need a separate cable modem to provide internet access.
Retired_Member
Aug 21, 2022Thanks kitsap
In response to your questions:
We currently stream without issues, on devices that do not use a software VPN.
I am considering "adding" VPN to my router, which has that capability as you wrote in your response.
Streaming issues would be when the entity knows you are using a VPN and will not allow streaming of their product. I am wondering if those streaming issues would arise with the VPN on the router as our devices we stream to would then be using the router VPN.
Kitsap
Aug 21, 2022Master
