SimonSaba
Jan 08, 2023Guide
CAX30 - AX2700 does not reconnect after Internet outage
If we have an Internet outage, the four lights, power (obviously), upstream, downstream, and Internet stay lit. The OOMA Telo box, on the otherhand, shows a red (no Internet) light as well as no Inte...
- Jan 09, 2023
Could be how the ISP's cmts is booting up causing the CAX to need to be rebooted after their cmts boots.
Jan 08, 2023Guru - Experienced User
Are they able to see it online?
Have you tried resetting it? Maybe something was corrupted in the outage
SimonSaba
Jan 08, 2023Guide
Yes. It still will not reconnect after an outage. It's more of an annoyance than anything else and we've been living with it for more than a year because the modem it replaced from Optimum was not compatible with some of our devices that require a separate 2.4 GHz wireless. It doesn't happen frequently. What the ISP Says is that they bought a system that was in need of a lot of work so to be patient with the outages. Because I worked for the previous company, Optimum is not blowing smoke on this.
- plemansJan 08, 2023Guru - Experienced User
So optimum is having issues?
If so, not much to do with the modem. More their service.
