smazzurco
Aug 07, 2023Aspirant
CAX30 - Comcast says it doesn't support my speeds
I have 1200Mbps cable from Comcast/Xfinity. Speeds seem to be slower since I changed to it even though it is labeled as a "multigig" speeds on the package. It should be able to handle my speeds, co...
Aug 07, 2023Guru - Experienced User
Have them set you to 800Mpbs.
The LAN side ports are limited to 1000Mpbs max so you'll never see over this speed.
smazzurco
Aug 08, 2023Aspirant
Why do they advertise it as speeds up to 2.7Gbs and on the box label it a multi gig modem/router?
Looks like ill be taking this one back. Any recommendations?
- KitsapAug 08, 2023Master
smazzurco wrote:Why do they advertise it as speeds up to 2.7Gbs and on the box label it a multi gig modem/router?
Looks like ill be taking this one back. Any recommendations?Yes, start off by doing some background reading so you can tell the difference between specifications and marketing hype. The 2.7 Gbps - Multi-gig is all marketing hype. Duckware knows their stuff and will arm you with the knowledge to make an intelligent choice of hardware. Here is the link:
https://www.duckware.com/tech/wifi-in-the-us.html
Bookmark the link as the document is updated on a regular basis.
Purchase two devices to replace your combination modem/router. The technology refresh time line for cable modems is going to be stable for some time with DOCSIS 3.1. The technology refresh time line for routers is significantly shorter.
Look for a modem that has a 2.5 Gbps output port.
You are going to have to look hard for a router that has both 2.5 Gbps input and 2.5 Gbps output connections. Some of the newer mesh systems do.
- FURRYe38Aug 09, 2023Guru - Experienced User
the 2.7Gb is a combined marketing speed. Not actual.
The LAN ports on the modem only support 1Gb max connection rate.
Modems have have multi gig ports beyond 1Gb are CAX80, CM2000 and CM2050v currently.
