Brent56
Apr 20, 2023Follower
CAX30 - constantly getting disconnected
I’ve the same issue, constantly getting disconnected or extremely slow internet and having to reboot several times in iPad…after reboot, no issues for ,maybe, an hour or so.then ,it’s like,repeat abo...
- Apr 20, 2023
Be sure for Apple and Android devices, that any MAC Address randomizing features are disabled:
Is Smart Connect Enabled?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-routerWhat Firmware version is currently loaded?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Apr 20, 2023Guru - Experienced User
