bozojoe's avatar
bozojoe
Guide
Jul 07, 2021
cax30 - dhcp reservation 0.0.0.0
Im trying to set a DHCP reservation for a MAC from a dell PC.   However no matter what value I input for the IP the user interface resets the IP to 0.0.0.0 after hitting the "add" button.
  • Found the solution.
    the IP must be in the DHCP range.    my range happened to start at x.x.x.100 to x.x.x.253.
    I wanted a reservation of x.x.x.50.     that didnt work
    however
    inputing x.x.x.150   DID work.
    however
    • FURRYe38's avatar
      Yes to reserve and IP address, it must be in the DHCP IP address range. Anything outside of the IP address pool range can be set for a STATIC IP address which is set ON devices, not the router.
      • bozojoe's avatar
        bozojoe
        Guide
        Your right, I kinda forgot all my networking skills this week.    Too bad the UI doesnt remind the user.
