bozojoe
Jul 07, 2021Guide
cax30 - dhcp reservation 0.0.0.0
Im trying to set a DHCP reservation for a MAC from a dell PC. However no matter what value I input for the IP the user interface resets the IP to 0.0.0.0 after hitting the "add" button.
- Jul 07, 2021
Found the solution.
the IP must be in the DHCP range. my range happened to start at x.x.x.100 to x.x.x.253.
I wanted a reservation of x.x.x.50. that didnt work
however
inputing x.x.x.150 DID work.
Jul 07, 2021Guru - Experienced User
:smileywink:
Ya, would be nice...
Glad you got it working.
antinode
Jul 07, 2021Guru
> Yes to reserve [an] IP address, it must be in the DHCP IP address
> range. Anything outside of the IP address pool range can be set for a
> STATIC IP address which is set ON devices, not the router.
Why? Around here (D7000[v1], V1.0.1.78_1.0.1), that would be
considered a firmware bug.
My DHCP pool range is ".224" - ".239". I have 23 address
reservations, all of which are outside the pool. I also have some
devices with static (ex-pool) addresses.
Obviously, there's no compelling reason for such a restriction.
> Found the solution.
Not what I'd call a "solution".
> [...] Too bad the UI doesnt remind the user.
I'd say, "Too bad the (unspecified) firmware's defective."
