Jeckre
Jan 13, 2023Aspirant
CAX30 - Disables internet on name change.
Was there a fix for the issue?
I am having the exact same issue on my CAX30 that I have had for over a year now.
Jeckre
I had replied to a post about a CAX30 not workiing after changing the network Names but I guess it created a new post as well.
So the issue I'm having is this.
I have a CAX30 modem router combo that I have had for just over a year and has worked great till now.
Cant get either 2.4 or 5 to connect to any devices, all devices connect and then say no Ip.
I factory reset the unit, Upon first set up and default name I can connect to the internet just fine no issues on phone or laptop.
I go to change the name back to what the name was before and I then get Issue with getting no IP.
The new name is the same name as I had before. I have SEVERAL smart devices that I cannot get to now to change them to a new network name so I want to get the same name set up again so they will connect.
The name is a basic name like "Jeckre" the password is basic but works ex "Password123" nothing weird or anything.
I have factory reset a few times I manualy added the current firmware 1.4.11.2 and even tried to downgrade firmware back to
1.4.10.10 and have same issue with both.
I also tried to change the name to just Test 1 and Test 2 and a password of litterally Password123
it does the same thing of then my devices wont connect and say No IP.
so everything works when on default Name but changing to a new name breaks it.
Thanks for any help anyone can give.
- FURRYe38Jan 13, 2023Guru - Experienced User
What devices do you have connected?
Be sure to forget any prior saved SSID name profiles after you make he change and see if the devices will connect.
- JeckreJan 13, 2023Aspirant
Hey Furry i sent you a message with specifics but wanted to give a basic answer here for people who see this issue later.
No i dont have anything odd in the name it is one upercase and then lowercase for the name like "Jeckre" and password is one upper a few lower and two numbers like "Password12"
I have made sure to remove the saved network SSID on my devices and even tried a brand new name to test. I did Test1 and Test2 and litterally did Password1 as the password and had the same issue.
Thanks!
Got it.
So you have Smart Connect disabled. What happens if you enable it for testing this and give a simple name and PW?
Also what security mode are you using on the modem? As a quick test, set it to NONE temporarily to see if your wifi devices connect. Then if they do set to WPA2 and AES then try again.
