corbintx
Oct 16, 2022Aspirant
CAX30 - Disables internet on network name change.
Helllo, I have a CAX30 that I purchased from Costo (and also exchanged as of yesterday), that when I complete my network setup in the nighthawk app with a wifi network name change, disables my in...
Oct 16, 2022Guru - Experienced User
What happens if you change the ssid name through the browser and not the app?
- corbintxOct 16, 2022Aspirant
Unfortunately the exact same thing.
I've tested this now on both modems...
I have no idea why this is causing such an issue, but I will probably end up having to just return the modem if it can't handle simple network name changes...
If i leave it as the default netgearxx network, i have no issue.
this occurs on both the app and the browser.
- plemansOct 17, 2022Guru - Experienced User
What firmware version is on the CAX?
- corbintxOct 17, 2022AspirantWhen it goes through the setup it auto updated to the most recent. It’s literally out of the box.
Their auto update doesn't always work. Its why we ask what version its on
