KP343
Dec 07, 2023Aspirant
CAX30 - Disables internet on network name change
Is there a fix for this issue yet? I'm experiencing the same thing.
Dec 07, 2023Guru - Experienced User
What name change are you referring too? Wifi SSID name?
What FW version is loaded on your CAX30?
What devices are you connecting?
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
