net6574
Dec 16, 2021Aspirant
CAX30 - Google Pixel 3XL
I have a Google Pixel 3XL. Internet was working fine with old modem and mobile data. But issues started after I got Netgear CAX30 cabel modem router and activated with my cable provider. The iss...
Dec 16, 2021Guru - Experienced User
do you have IPv6 enabled?
Are you using smart connect?
Are you connecting to the 2.4ghz or the 5ghz?
Any other device having issues?
net6574
Here are the answers -
do you have IPv6 enabled? : Yes IPv6 is enabled.
Are you using smart connect? : I am not using smart connect
Are you connecting to the 2.4ghz or the 5ghz? : Yes both
Any other device having issues? : Yes all other devices work
As mentioned earlier, My Google Pixel 3XL works well with other cable modems and mobile data.
