net6574
Dec 16, 2021Aspirant
CAX30 - Google Pixel 3XL
I have a Google Pixel 3XL. Internet was working fine with old modem and mobile data. But issues started after I got Netgear CAX30 cabel modem router and activated with my cable provider. The iss...
net6574
Here are the answers -
do you have IPv6 enabled? : Yes IPv6 is enabled.
Are you using smart connect? : I am not using smart connect
Are you connecting to the 2.4ghz or the 5ghz? : Yes both
Any other device having issues? : Yes all other devices work
As mentioned earlier, My Google Pixel 3XL works well with other cable modems and mobile data.
