mikaelderderian
Sep 28, 2022Aspirant
CAX30 - losing signal every few minutes
MODEM-ROUTER purchased from costco in May 2022. Problem started 2 weeks ago and keeps happening every few minutes. I work from home and can't have any type of teams or zoom meeting without losing s...
Sep 28, 2022Guru - Experienced User
Happens on wired devices as well?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
mikaelderderian
Sep 29, 2022Aspirant
Thank you so much for the support. I just changed the channels as suggested and issue continues.
Note that I have 3 WIFI neighbors - their network names are very different.
Cable type and setup has not been changed since may when it was working perfectly (issue started couple weeks ago)
| Hardware Version | V1.01 |
| Firmware Version | V1.4.10.10 |
| Cable Firmware Version | V1.04.09 |
Here is the data from the cable connection tab.
Cable Connection
| <tabindex=-1>Startup Procedure</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Downstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Upstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Downstream OFDM Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
- FURRYe38Sep 29, 2022Guru - Experienced User
Well power is a bit on the low side but with in specs.
Zeros for Correct and un-correctables.
Has a factory reset and setup from scratch been performed.
Try reducing the WiFi power on the modem from 100% to 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
Can you find out what channels your Neighbors are using?
Set channels 1 and 40 or 11 and 48 or 149 for the wifi radios.
Please post a copy of the Event Logs as well here.
- mikaelderderianSep 29, 2022Aspirant
Thanks again.
I did change to 50% but issue continues - same for the channels.
Manufacturing reset has been done last week.
I don't have an easy way to get the channel from my neighbors...
Here is the log event:
Time Priority Description 2022-09-29 11:44:28 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1; 2022-09-29 11:44:23 Notice (6) DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1; 2022-09-29 11:44:22 Notice (6) TLV-11 - unrecognized OID;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1; 2022-09-29 11:44:21 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:30 Notice (6) Honoring MDD; IP provisioning mode = IPv4 1970-01-01 00:00:24 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:32 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:25 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:32 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:25 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:32 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:25 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2022-09-22 17:39:58 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:32 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:24 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2022-09-22 14:59:21 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1; 1970-01-01 00:00:29 Critical (3) SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1; 2022-09-21 08:49:51 Critical (3) Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=80:cc:9c:df:26:18;CMTS-MAC=00:01:5c:78:c6:6e;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Sep 29, 2022Guru - Experienced User
You some Criticals that the ISP needs to review and resolve.
I would have the ISP online with you while checking there logs and signal if they can see the modem go off line...
