MarkBolotin1
Sep 04, 2024Aspirant
CAX30---streaming issue
CAX30 modem router, I am having streaming issues on one TV. It goes into a buffering mode at times...to the point where it becomes unwatchable. I have taken the following steps 1. Went to a fas...
- Sep 17, 2024
Thank you.
I moved the extender close enough to the TV that I could connect them by ethernet cable. It's about a week with no issues.
Thanks, again
Sep 04, 2024Guru - Experienced User
some TV's aren't known for having the best wifi cards in them. And the single band ones are atrocious.
You might be better to use that extender (not sure what one you got) and hardwire the tv into the extender.
What extender did you get?
Or switch to a powerline system for the tv.
- MarkBolotin1Sep 17, 2024Aspirant
Thank you.
Thanks, again
