MarkBolotin1
Sep 04, 2024Aspirant
CAX30---streaming issue
CAX30 modem router, I am having streaming issues on one TV. It goes into a buffering mode at times...to the point where it becomes unwatchable. I have taken the following steps 1. Went to a fas...
- Sep 17, 2024
Thank you.
I moved the extender close enough to the TV that I could connect them by ethernet cable. It's about a week with no issues.
Thanks, again
nainamartin
Oct 21, 2026Aspirant
Streaming issues on a CAX30 router can sometimes be caused by network congestion, unstable Wi-Fi, or buffering settings rather than the streaming app itself. Checking the router firmware, restarting the router, and testing the connection on another device can help narrow down the cause. It is also worth checking whether different reproductores de video experience the same problem, since playback compatibility, video quality, and buffering behavior can vary between players. Testing a lower resolution and using a stable connection may improve playback and help identify whether the issue comes from the network or the media player.
