ddeadguyy
Feb 25, 2024Aspirant
CAX30 : MTU adjustments have no impact, and resets to 1500 when rebooted
CAX30, without the S. Firmware Version V1.4.12.2 On Spectrum cable in Western New York State. I own it. I did not lease it from Spectrum. One of the reasons for ownership is so I can reduce M...
- Feb 25, 2024
Resolved by updating my stale router firmware.
Built-in firmware update support didn't find it. Installed manually, then factory-reset, then set DHCP pool to 100-200.
Cable firmware was already current.
ddeadguyy
Feb 25, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
- ddeadguyyFeb 26, 2024AspirantFor the benefit of anyone else who finds this later, the “reducing the value has no impact on my ping fragmentation tests” part was a feature of my Meraki MX67W. My home computer, connected directly to the CAX30, was not impacted.
- FURRYe38Mar 06, 2024Guru - Experienced User
FYI, new FW is available:
