Akiha
May 23, 2022Guide
CAX30-100NAS Intermittent Connection drops/poor upload/error in log
Netgear Nighthawk AX2700 (I can't find this model on the drop down, but it's what amazon says it is) Hello, I've been having an issue with my upload speeds during the night (9pm - 3am). While...
Akiha
May 23, 2022Guide
Akiha
May 23, 2022Guide
- AkihaMay 23, 2022Guide
Final attachment. I'm pretty sure this is Comcast's issue, but I thought I'd post here to be safe.
- plemansMay 23, 2022Guru - Experienced User
You do have quite a few errors in the line and logs are indicating line issues.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s (xfinity) charge if the wiring issue is in the home. So this helps prevent this.
