Bhomz
Feb 22, 2023Tutor
CAX30 5ghz issues
Woke up 3 days ago my 5ghz band constantly dropping need to reset the modem it will come back again run for about 40mins and drop again did a factory reset same thing happened only affects the 5ghz ba...
Feb 23, 2023Guru - Experienced User
What FW are you using?
- BhomzFeb 23, 2023TutorThe latest FW
- BhomzFeb 23, 2023TutorDiscovered this site when i was looking for solution i never called my ISP cause i know this is not an ISP problem, my PC and laptop is running fine theyre all wifi 6, i saw that some people having issues with CAX30 with the new firmware but they losing internet connection not mine am just losing 5ghz band connection weird thing not all the devices having problem with it, my new samsung s23ultra has the biggest problem it will not even detect the 5ghz band
- BhomzFeb 23, 2023TutorThis is on netgear this is a firmware problem i was able to recreate the firmware bug that the latest update created, turn on your TM and reboot you gonna lose internet connection turn it off it will come back, am about ready to give up on this for years ive been using TENDA without any headaches bought this nighthawk because of it sleek look and specs using it for 14months twice i already factory reset, once it factory reset itself its always the wifi radios never have problem with the wired connection, i might use this as a modem and buy me a router i guess if netgear doesnt do anything
