EricH195
Nov 27, 2022Aspirant
CAX30 5GHZ networks (regular and guest) are gone
2.4GHZ networks work fine, but all of a sudden there are no 5GHZ networks. In Nighthawk, WIFI Settings lists my 5GHZ WIFI Network Name (SSID) and the Network Key (Password), same for 5G-Guest is also...
EricH195
The 5 GHZ LED light is off. The 2GHZ light is on/flashing.
Kitsap
Nov 27, 2022Master
EricH195 wrote:The 5 GHZ LED light is off. The 2GHZ light is on/flashing.
From within the graphical user interface (GUI), have you shut off the 5 GHz SSID broadcast?
- EricH195Dec 01, 2022Aspirant
I use Nighthawk to configure everything. I cannot find any setting pertaining to something called SSID broadcast. Should I be using a web browser to check configuration?
- KitsapDec 01, 2022Master
EricH195 wrote:I use Nighthawk to configure everything. I cannot find any setting pertaining to something called SSID broadcast. Should I be using a web browser to check configuration?
YES! And if possible, connected directly to the CAX30 via an Ethernet cable. Phone applications and Wi-Fi connections have a track record of occasionally introducing problems that can be avoided with the web browser and Ethernet cable.
