KO45BIN
Feb 22, 2023Guide
CAX30 AX2700 ReadyShare shows connected drive but the folder is empty
Hi, any help would be appreciated. I have CAX30 AX2700 modem router with USB connected external 8GB drive. I use the drive for playing videos only through Plex Media. The system is Windows 11 Home. ...
Feb 22, 2023Guru - Experienced User
Might have been a firmware update that caused it. Unsure but we've been seeing multiple reports lately about the CAX30.
Random question is if you've got plex installed on something already, why not have the drive directly into that device? The delay from the plex server actually having to run through the network to connect to the drive and then stream that to devices causes slow downs and lag. It's better to have it directly connected to the plex media server device.
- KO45BINFeb 22, 2023Guide
Thanks, from my understanding the computer has to be on at all times to be able to access the server. This was the only reason why I connected it this way. Most of the time I had no issues streaming, but I'll try connecting to the desktop directly and see what happens.
- plemansFeb 22, 2023Guru - Experienced User
The computer does need to be on to manage the plex server. but if its not on, you're plex isn't on/in use, so you're not accessing the data. Or am I missing something in your setup?
I'm streaming the content of the external drive to 2 different TV's which have Plex apps installed. So if the computer is off the Plex server will be off too and Plex apps won't be able to access the content. Having it on the router makes it accessible at any time. Unless I'm missing something here
