KO45BIN
Feb 22, 2023Guide
CAX30 AX2700 ReadyShare shows connected drive but the folder is empty
Hi, any help would be appreciated. I have CAX30 AX2700 modem router with USB connected external 8GB drive. I use the drive for playing videos only through Plex Media. The system is Windows 11 Home. ...
KO45BIN
Feb 22, 2023Guide
Thanks, from my understanding the computer has to be on at all times to be able to access the server. This was the only reason why I connected it this way. Most of the time I had no issues streaming, but I'll try connecting to the desktop directly and see what happens.
Feb 22, 2023Guru - Experienced User
The computer does need to be on to manage the plex server. but if its not on, you're plex isn't on/in use, so you're not accessing the data. Or am I missing something in your setup?
