KO45BIN
Feb 22, 2023Guide
CAX30 AX2700 ReadyShare shows connected drive but the folder is empty
Hi, any help would be appreciated. I have CAX30 AX2700 modem router with USB connected external 8GB drive. I use the drive for playing videos only through Plex Media. The system is Windows 11 Home. ...
Feb 22, 2023Guru - Experienced User
so the photo you shows (from my experience) is of an actual plex server and not the app that tv's run.
What is it running on?
Can a pc/laptop see the attached storage on the network?
KO45BIN
Feb 22, 2023Guide
PC can't see attached storage unless I map the drive on Network. Then I can add it through readyshare and shows in the This PC folder but when I click on it it says the folder is empty
Additionally when I log in to the router, I can view the drive, when I go to edit network folder and click browse the folder the whole drive shows up but only Recycle bin folders are visible.
- plemansFeb 22, 2023Guru - Experienced User
Stick a file in the root of the hard drive. Not in separate folders and see if it can see it.
Also, how long has this been going on? there was a firmware update 2/8. maybe that corrupted something.
you could always try downgrading.
