Ttwinsupra
Feb 21, 2023Initiate
Cax30 constant issues
Hi, ive had nothing but issues since i upgraded to this cax30 router modem... is it defective? Just a bad modem? Randomly drops services multiple times and cant get internet back, un plug re plug forg...
michaelkenward
Feb 21, 2023Guru - Experienced User
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge. As you are asking about a specific piece of hardware, a cable modem/router, this isn't the best place to ask that question.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
