Bradylaura2000
Jul 19, 2022Aspirant
CAX30 (Costco) will randomly stop passing traffic for some devices but not all
Random wifi devices lose connectivity intermittently. I know the signal is good because the TV never stops! Noticeable drops: Smart plugs, Blink hub, Roku, iPhone12 Seem ok: LG tv, Firesticks, iP...
Jul 19, 2022Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Make sure the laptop wifi drivers are up to date.
If present, Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
You have some criticals that need to be looked at by the ISP.
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Bradylaura2000
Thanks for the reply!
Firmware is 1.4.10.8 and all my drivers are up to date. Only a couple neighbor's with wifi not too close. From my most distant device and closest to neighbors, I ran a channel scanner and attached the output but could not attach the output. I'm alone on channel 1 but manually changed it to 1 from Auto. The 5ghz is set at 153 and the next closest ssid is a -30 bd difference from me. Hope that makes sense!
In wireless settings I have Beamforming and MIMO checked, Airtime Fairness is disabled though. (Change?)
I just read the another thread you're in with iRyan about reserved IPs being an issue - and I do that. DHCP is 192.168.1.200-250 with a couple things reserved as .100-.102. Sounds like i need to stop reserving and manually configuring. (at work we call it SDHCP - static dynamic... grumble. anyways!)
90% of the time I'm sitting beside the router when my single connection drops. If I do default, are there any "features" I should leave alone?
Is there any trick getting by the level 1 ISP support that asks you to reboot when you just need to check correct provisioning/line quality? I get it - but I think everybody on this site is beyond that 🙂
I hope this attachment is legible. Thank you guruFURRYe38 !
- Bradylaura2000Jul 21, 2022AspirantTiny update: streaming on Roku while googling around on iPhone12, both on 5Ghz. The Roku drops connection, so I reboot it. Everything else is still connected that I can tell.
After Roku reboots and reconnects I remembered I have this little ping utility - at least now I know it’s the WiFi/switch side glitching out!
Any other valuable utility I could run for info gathering? I beta tested a RAX500 that ran better this.
Silly question - when I default the router, is it a dumb idea to import this current config or rebuild from scratch? - FURRYe38Jul 21, 2022Guru - Experienced User
1. Your power levels are way too low:
2. You have a ton of correct and un-correctables that should be zero. ISP needs to help you check the signal on the line and ensure all coax fittings are right and snug fitting. Remove any coax line splitters.
IP address reservations should be with in the Default DHCP IP address pool range. Static IP addresses are set ON devices and out side the Default DHCP IP address pool range
and attached the output but could not attach the output. I'm alone on channel 1 but manually changed it to 1 from Auto. The 5ghz is set at 153 and the next closest ssid is a -30 bd difference from me. Hope that makes sense!In wireless settings I have Beamforming and MIMO checked, Airtime Fairness is disabled though. (Change?)
