Whiskerjdgs1617
Dec 29, 2023Follower
CAX30 dead with 1 2 3 4 lights stuck on after three months of use
I saw that a few other people had this issue as well. The AX6 WiFi Cable Modem Router Model CAX30 cost a pretty good chunk of change (even at Costco $300+)), and after three months of use, I got ...
Dec 29, 2023Guru - Experienced User
Disconnect the ISP coax line from the modem. Perform a 30-30-30 reset. Does this clear the LED condition at all?
If it seems to clear the LED condition, re-connect the ISP coax line to the modem and see if you can walk thru the setup wizard with a wired PC and web browser at 192.168.1.1.
If this fails, you'll need to get in contact with NG suport:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/support/contact.aspx
Then clicking on "Get answers about NETGEAR products before I buy" then clicking on "Networking for Home" then "Chat with us".
Good Luck
