Dawees
Nov 01, 2024Follower
CAX30 Downstream SNR Partial
Hello, i am showing Poor Cable Connection, and it states that the Downstream SNR specifically as the issue. Yellow color and marked "partial". the following is my Diagnostic result, thank yo...
Nov 02, 2024Guru - Experienced User
your power levels are out of spec too. And you have non-locked channels.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
And a request, when posting these values, simply take a screensnip and post the photo. Much easier to read
