JesseFaulk
Dec 19, 2023Aspirant
Cax30 dropping internet connectivity
I'm having a similar issue, with signal dropping randomly throughout the day. Based on the last comment, it sounds like my Correctables and Uncorrectables numbers are terrible. Cox recently ran fresh...
Dec 19, 2023Guru - Experienced User
Please post a copy and paste of the modems event log page.
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
You have a ton of Correctables and Un-correctables that should be zero.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- JesseFaulkDec 19, 2023Aspirant
Firmware Version V1.4.12.2, Also just realized it's a CAX30, not a CAX80, but I'm guessing the issues are still very relevant.
Here's a sheet of the full event log in case. Most recent is pasted below (full event log exceed character max for post).
Time Priority Description 2023-12-19 10:35:01 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 10 13; New Profile: 9 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 10:10:38 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 9 13; New Profile: 10 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 9:34:59 Error (4) DBC-ACK not received;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 9:34:56 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 12 13; New Profile: 9 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 9:19:50 Warning (5) Dynamic Range Window violation 2023-12-19 9:19:50 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 9:15:21 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 9:09:56 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 10 13; New Profile: 11 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 9:09:30 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 9 13; New Profile: 10 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 9:07:51 Warning (5) Dynamic Range Window violation 2023-12-19 9:07:51 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 8:34:53 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 10 13; New Profile: 9 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 8:13:36 Warning (5) Dynamic Range Window violation 2023-12-19 8:13:36 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 7:48:50 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 9 13; New Profile: 10 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 6:47:23 Warning (5) Dynamic Range Window violation 2023-12-19 6:47:23 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 5:41:09 Warning (5) Dynamic Range Window violation 2023-12-19 5:41:09 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 5:34:35 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 10 13; New Profile: 9 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 5:19:45 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 9 13; New Profile: 10 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 4:36:54 Warning (5) Dynamic Range Window violation 2023-12-19 4:36:54 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 4:34:30 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 10 13; New Profile: 9 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 3:57:27 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 9 13; New Profile: 10 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 3:34:26 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 10 13; New Profile: 9 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 3:32:20 Warning (5) Dynamic Range Window violation 2023-12-19 3:32:20 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; 2023-12-19 3:16:53 Notice (6) US profile assignment change. US Chan ID: 8; Previous Profile: 9 13; New Profile: 10 13.;CM-MAC=34:98:b5:90:ce:08;CMTS-MAC=b0:8b:d0:6d:d3:1f;CM-QOS=1.1;CM-VER=3.1; - FURRYe38Dec 19, 2023Guru - Experienced User
Ok, will get the subject corrected.
In meantime,
Can update FW:
However, Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem. That and the other suggestions needs to be looked into to help get the modem signal in better working condition.
