popcornpickle
Mar 06, 2024Aspirant
CAX30 dropping wifi connection to all devices
My CAX30 router randomly drops all wifi connections at once. They typically automatically restore within 5 minutes without having to interfere (i.e, restart,..). These drops happen seemingly random. ...
- Mar 19, 2024
Update:
I switched out the +10db attenuator with +12db forward path attenutator, and have good power up- and downstream, 44 and 2 dBmV respectively, with no (un-)correcatables.
There haven't been any outages for almost a week, but I there was one critical event 4 days ago. I'll keep monitoring and contact the ISP if critical events won't stop
popcornpickle
Found out several critical events in the log. Should I reach out to my ISP?
Mar 07, 2024Guru - Experienced User
Yes. Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
- popcornpickleMar 07, 2024Aspirant
Here is the cable connection drop (attached)
Firmware version is V2.1.6.2 (and cable firmware V1.04.10)
- popcornpickleMar 10, 2024Aspirant
I've attached the current logs after 1) updating FW to 2.2.2.2, 2) increasing attenuation from +6 to +10db, 3) changing coax cable and removing an elbow connector.
The last critical from late last night coincides when I switched out the hardware, and I may have left the power on...
So far no wifi drops and criticals (fingers crossed). Is the upstream power of 54dbmV too high?
- FURRYe38Mar 10, 2024Guru - Experienced User
Ok, Power Looks good now, even uplink.
Correctables and Un-Correctables are zeros which is good.
I see criciticals however that maybe due ot the modem coming on line and doing it's intial thing and you making changes to the coax line. Monitor this in the next day or two. Shouldn't see any Events accept for notices only. If so, your all good.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-router- popcornpickleMar 19, 2024Aspirant
Update:
