popcornpickle
Mar 06, 2024Aspirant
CAX30 dropping wifi connection to all devices
My CAX30 router randomly drops all wifi connections at once. They typically automatically restore within 5 minutes without having to interfere (i.e, restart,..). These drops happen seemingly random. ...
- Mar 19, 2024
Update:
I switched out the +10db attenuator with +12db forward path attenutator, and have good power up- and downstream, 44 and 2 dBmV respectively, with no (un-)correcatables.
There haven't been any outages for almost a week, but I there was one critical event 4 days ago. I'll keep monitoring and contact the ISP if critical events won't stop
Mar 10, 2024Guru - Experienced User
Ok, Power Looks good now, even uplink.
Correctables and Un-Correctables are zeros which is good.
I see criciticals however that maybe due ot the modem coming on line and doing it's intial thing and you making changes to the coax line. Monitor this in the next day or two. Shouldn't see any Events accept for notices only. If so, your all good.
popcornpickle
Mar 19, 2024Aspirant
Update:
