SimonSaba
Jun 29, 2024Guide
CAX30 drops cable connection 2-3 times a day
Netgear CAX30 Firmware 2.2.2.2 Devices connect through WiFi and wired connections through an unmanaged switch. The CAX30 was pretty solid up until 2 weeks ago when the Internet connection began ...
- Jul 29, 2024
Current uptime is 4 days, but that's because we had power go out. Before that, uptime was over a week. Seems like reducing downstream voltages below 7 dBmV may have corrected the problem. I say MAY because now the upstream voltages are 1 dBmV higher than recommended on two of the channels. The other 2 are within specs. The tech put a splitter on to reduce the voltages. If this becomes problematic again, I'll switch the splitter for a 3 dB attenuator.
Thanks for everyone's help with this. I'll mark it as solved.
SimonSaba
Jul 29, 2024Guide
Jul 29, 2024Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
