SimonSaba
Aug 28, 2024Guide
CAX30 Drops Internet Connection
CAX30 modem/router with firmware 2.2.2.2 My CAX30 had been solid for about the past 2 1/2 months after a tech came out to install a splitter to reduce power levels. Before installing the splitter...
Aug 28, 2024Guru - Experienced User
Please post a copy and paste of the modems event log page.
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
If your seeing over +7dbm on the power levels, then find you a -6dbm coax line attenuator.
SimonSaba
Aug 28, 2024Guide
I'm not seeing elevated downstream voltages. As I said in the post, the downstream voltages are now running less than 7 dBmV with either the splitter that Optimum provided or a 3 dB attenuator that I placed on the line. I do see elevated upstream voltages with either the splitter or the attenuator attached. Optimum warned me that this would happen
The attached Event Log shows warnings and errors since the error changed from a sync timing error to a RNG-RSP CCAP Commanded Power error and Dynamic Range Window violation. I also included a cable connection diagnostic. I removed MAC addresses for privacy concerns. Is this error occurring because the upstream power levels are now elevated?
- FURRYe38Aug 28, 2024Guru - Experienced User
Ok, power looks good.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/Has a factory reset and setup from scratch been performed since last FW update?
- SimonSabaAug 28, 2024Guide
Did all of this the last time the tech was out.
Can you explain the two error messages:
Before installing the splitter, the message was
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
After installing the splitter, the messages are
RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;
Both these messages began showing up after the tech installed the splitter to reduce downstream voltages. With the splitter or 3 db attenuator in place, the the downstream voltages are within specs but the upstream voltages are higher than specs. Are these messages related to the upstream voltages being higher than spec?
Something the ISP needs to look at.
