SimonSaba
Aug 28, 2024Guide
CAX30 Drops Internet Connection
CAX30 modem/router with firmware 2.2.2.2 My CAX30 had been solid for about the past 2 1/2 months after a tech came out to install a splitter to reduce power levels. Before installing the splitter...
Aug 28, 2024Guru - Experienced User
Ok, power looks good.
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
SimonSaba
Aug 28, 2024Guide
Did all of this the last time the tech was out.
Can you explain the two error messages:
Before installing the splitter, the message was
SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
After installing the splitter, the messages are
Dynamic Range Window violation
RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;
Both these messages began showing up after the tech installed the splitter to reduce downstream voltages. With the splitter or 3 db attenuator in place, the the downstream voltages are within specs but the upstream voltages are higher than specs. Are these messages related to the upstream voltages being higher than spec?
- FURRYe38Aug 28, 2024Guru - Experienced User
Something the ISP needs to look at.
- SimonSabaAug 30, 2024Guide
The tech came but said that the voltages on the line were within their specs (+12 dBmV to -10 dBmV) even though they are not within the specs of the CAX30 that Optimum's website says it compatible and most other modems. All Optimum's website says is that any DOCSIS 3.1 modem is compatible. Also, he really didn't know what the error messages that the CAX30 was reporting meant.
After doing some more research, I found a 6 dB attenuator on Amazon that will reduce downstream voltages while not affecting upstream voltages. The reason that's important is that when a regular 3 dB or 6 dB attenuator or cable splitter is attached, downstream voltages are reduced, but upstream voltages increase. This caused a different error, one related to upstream voltages, to be reported when the Internet connection went down. With this different attenuator, downstream voltages are between 2.2 dBmV and 3.4 dBmv. The upstream voltages remain at 45.8 dBmV to 46.3 dBmV. Both are within specs for the CAX 30.
The device is a PPC FPA6-54 Forward Path Attenuator 6dB 75 Ohms for DOCSIS Cable TV Box and Modem. In the product description it says that "PPC’s forward path attenuators provide a fixed level of attenuation within the downstream frequencies without affecting upstream frequencies." I had it on hand when the tech arrived. He had no idea that such a device existed.
There may be some issues with using this forward path attenuator if your cable company uses upstream channels that overlap downstream channels. This device assumes that all upstream channels are 42 MHz and below. To meet the needs of faster speeds, some newer cable systems are using upstream frequencies in the 85 MHz and 108 MHz ranges. This device will also reduce power to those upstream frequencies if your cable system uses them. For me, this is not an issue as all upstream frequencies are sub 42MHz.
I'm going to wait a week or so before marking this thread as solved to make sure that the connection is really stable.
- FURRYe38Aug 30, 2024Guru - Experienced User
Power levels should follow that NG puts forth for there modems:
Looks like you found something that got the power with in those specs.
Come back and let us know if it works fully after a few days.
