oldguy76's avatar
oldguy76
Initiate
Nov 30, 2023
CAX30 FIRMWARE UPDATE
CAX30 cable modem/router  firmware version v1.4.12.2
I'm having intermittent internet problems such as the net drops or wifi not responding.
Working with my provider (Sparklight) but thought I would check for a firmware update.
I see v2.2.1.12 is available yet using the Netgear app for IOS, I'm told my firmware is up to date.
Should I update to the new version or stay the same?
Thanks
  • plemans's avatar
    I would upgrade. the newest version from the website has been pretty stable.
    the older one had a few issues
    • oldguy76's avatar
      oldguy76
      Initiate
      Thanks for your suggestion. I did upgrade and will see what happens going forward. It was confusing as when I did a check for an upgrade the reply was no upgrade was available. Again, thanks
      • FURRYe38's avatar
        Any progress on this?
