Mar 15, 2023Guru - Experienced User
CAX30 Firmware Version 1.4.11.2 Released
New Features and Enhancements: 11/30/2022 • Bug Fixes
NOTE: This version of FW is most stable. Any CAX30 user having problems with FW version 2.x that was pulled and your using hasn't been do...
DannyS22
Apr 15, 2023Guide
I see that you say to do the firmware update by a PC cable direct connection. My PC and my cable/modem/router are not even close or can be. Is this mandatory? My current firmware shows version 1.4.12.2. You're showing the beta version as 1.4.11.2. Am I to do the beta or is this not the latest to be beta tested?
Thanks
Danny
Apr 15, 2023Guru - Experienced User
Leave your current version v1.4.12.2 of FW as is. You'll be ok. I"m using same version of FW as well.
Thanks
Danny
