MileHighBurt
Mar 26, 2023Aspirant
CAX30 has to restart multiple times a day
I have the latest firmware and have had no issue in the past with connectivity. For some reason, after losing power during a storm a few weeks ago, I now have to restart the router every few hours b...
MileHighBurt
Mar 27, 2023Guru - Experienced User
What ISP are you with?
Please post a copy and paste of the modems connection status page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
The ISP needs to review and resolve all Criticals, Errors and Warnings seen in the Events log page...
- MileHighBurtApr 02, 2023Aspirant
So I got Spectrum out and there was a 15db drop in signal from the source to my modem/router. They removed a three way splitter that had a 5db attenuation and the modem passed the signal test. I Then connected my main PC to the modem via ethernet to test (if it did need to be reset again) to see if the wifi was having issues separate from the hard connection. I still have to reset router for wifi, though the ethernet doesnt have the same loss of signal. I tried disabling the smartconnect to see if that does anything? Maybe the router choosing between 2.4 and 5ghz is an issue? I also cleared the event log yesterday and recorded the current event log below. All firmwares are up to date.
2023-04-01 18:54:47Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2.;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
2023-04-01 18:54:46Notice (6)TLV-11 - unrecognized OID;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
2023-04-01 18:54:46Error (4)Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
2023-04-01 18:54:46Error (4)Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:31Notice (6)Overriding MDD IP initialization parameters; IP provisioning mode = IPv6
1970-01-01 00:00:28Critical (3)No Ranging Response received - T3 time-out;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:24Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
1970-01-01 00:00:29Critical (3)No Ranging Response received - T3 time-out;CM-MAC=34:98:b5:8f:de:38;CMTS-MAC=00:01:5c:64:50:55;CM-QOS=1.1;CM-VER=3.1;
- FURRYe38Apr 03, 2023Guru - Experienced User
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router- MileHighBurtApr 03, 2023Aspirant
Cable Information Hardware Version V1.01 Firmware Version V2.1.3.10 Cable Firmware Version V1.04.05
