iRoberto
Jan 16, 2022Aspirant
CAX30 How to block remote Web Access
Hello, I cannot find a way to block Remote Web Access to my Modem/Router. If I browse to my IP address it opens the login page of the Modem/Router> I would like to block remote access. Thanks ...
nielsvds
Jan 16, 2022Luminary
That is only local remote access from your network. You can only access it from a device that has an IP-adress in the range of your cable internet gateway (modem+router). External remote access is not possible. Read when not connected to the Wi-Fi with your devices.
- iRobertoJan 16, 2022AspirantI tried 2 different connections:
-satellite
-phone mobile data
And they both shows the login page.
So it is open.
iR- nielsvdsJan 16, 2022Luminary
You can not disable the web interface on Netgear home devices. In professional models your are remotely connecting using ssh or unsecure telnet and can disable web interface. Only changing the default password can block access to the configuration but a reset can always be performed..
- FURRYe38Jan 19, 2022Guru - Experienced User
I believe the user is referring to the WAN side access using a public IP address that should be disabled and there seeing accessibility on there CAX30. https://community.netgear.com/t5/Cable-Modems-Routers/CAX30-How-to-block-remote-Web-Access/m-p/2187101#M35596
