iRoberto
Jan 16, 2022Aspirant
CAX30 How to block remote Web Access
Hello,
I cannot find a way to block Remote Web Access to my Modem/Router.
If I browse to my IP address it opens the login page of the Modem/Router>
I would like to block remote access.
Thanks
iR
Is this happening while your not at home and at a remote location?
Do you have Anywhere access enabled with in the Nighthawk app under Settings?
Do you see Remote Management under Advanced tab/Admin?
What FW version is loaded on the modem?
- iRobertoAspirant
I get my Public IP Address of my cable modem.
I connect from another network, specifically ATT mobile or Starlink.
I start any browser, I insert the cable IP address and I get the
page of the CAX30 login.
Under Advance I have
-Security
-Administration
-Advanced Setupand none of them have Remote management
Hardware Version:
V1.01
Firmware Version:
V1.4.10.8
Cable Firmware Version:
V1.04.09I do have Anywhere access on the app, I just checked.
I am going to try to disable it.
PS: I have also a Netgear R7800 Router and that one has the option to turn Web Rccess Remotely off. That is why I am surprised that CAX30 does not have it.- iRobertoAspirant
I cannot disable Access Anywhere from the app.
iR
