pepbrow
Jun 07, 2022Aspirant
CAX30 in modem mode not getting IP from ISP
I set "Router Mode" to no in advanced settings. Xfinity shows modem as good to go, but on my end, CAX30 is not getting/picking up an IP. It's (the device) not Xfinity, so they can't really help. ...
Jun 07, 2022Guru - Experienced User
Which port on the back of the CAX are you using? Port #1 should be used to connect to for a wired PC or 1 external router.
Power OFF the CAX for 30 seconds then back ON with the wired PC or router connected to port #1...
