Cxriosity
Feb 22, 2023Tutor
CAX30 Internet/PC Issues
Hello, I’ve had this Router for about a year now, just ran into this issue a couple days ago. Around Midnight a night or two ago, I dropped all internet for no reason and I couldn’t get back on. I ...
Feb 22, 2023Guru - Experienced User
FYI,
Be sure to post in the right forum section.
Cxriosity
Feb 22, 2023Tutor
My apologies, this is actually my first time posting in a forum like this. I’ve been struggling, as other people may be too.
Reading the forum you linked, I did use TM as a fix, but now I can’t even get into the website or using the 192.— way. I even cleared my cache on my browsers, still no luck. In addition, when resetting it, the wifi isn’t discoverable.
So, do I wait on the FW to be fixed, or is there a way around?
- FURRYe38Feb 23, 2023Guru - Experienced User
Try a factory reset and setup from scratch.
If the CAX30 FW is using v2.1x, I recommend that you downgrade it to v1.4x:
- CxriosityFeb 23, 2023TutorI’ve factory reset for the 3rd time. The wifi still doesn’t show up. I can’t connect to the internet. Under my hardware and connection properties, my status is not operational and my connectivity for (IPv4/IPv6) says disconnected. It’s completely bricked I think. Because I’m supposed to have access to routerlogin.net after factory reset, but it literally doesn’t let me.
