iRoberto
Feb 22, 2023Aspirant
Cax30 Last night it died.
Exactly same problem here. Last night it died. There is no way to interface with the modem. My guarantee expired 1 month and 1/2 ago. Really upsetting.
Feb 23, 2023Guru - Experienced User
Try a factory reset on the CAX30 and setup using a wired PC and web browser:
- iRobertoFeb 23, 2023Aspirant
I reset it more than 10 times.
I have no access to WIFI: I get the WIFI is not found. Lights are on though.
I cannot use ethernet. When I plug in the cable the port's light does not even turn on.
It is def. bricked!And I am mad!
iR
I cannot access the modem to downgrade it.
It is def. bricked!Please do not remove my post again.
iR
I cannot access the modem!!!!
It is def. bricked!iR
Any suggestion????
I reset it more than 10 times. Using different ways/times.
It is def. bricked IMO!iR
